car stalling
cbrvan
philly
hello.
I have a issue, i replace stock turbo intake pipe (accordain hose) w/ cooleeze. in the process of putting parts back togather, i accidentally damage the honey comb in the afm (minor).
the car stalls in neutral after shifting sometime. it seems like there is not enough air is going thru. and i also notice the my rpm is really low @
idling 5-6k. I have cooleeze full intake pipe with hksssq bov. the car was running fine until i install the accordain hose. anyone what might cause the issue?
where do u adjust the rmp? i wan tto raise it to 7-8k @ idling.
rumptis
나는 제프가 당신을 사랑
Aug 16, 2005
814
North Vernon, IN
did you just replace the BOV as well from stock...if so venting in to atmosphere will do this compared to dumping it back into to accordion hose. I just had this problem and going back to the stock BOV cleared that right up.
cbrvan
philly
MDCmotorsports said:
You either have pirate air comming in from some where (boost leak) or your ecu needs to relearn if you unplugged the battery.
i just reset my ecu and it seems to help ....i'll have to recheck all my hoses this weekend. i was running fine with the bov before i replace the accordian hose...so you might be right about pirate. thanks fro the help.
