Ok its a Aristo 2jz swap in 1990 mk3. Ran perfectly fine until i decided i would do some upgrades. i know it needs to be tuned after all this but didnt think it would run this bad. if so let me know.
Driftmotion 67mm Single
Deatschwerks fuel pump
Aeromotive Fuel Pressure Regulator
550cc USDM Injectors
2JZ Injector resitor
SAFC NEO(set to all Zeros at the monent).
NGK plugs
HKS Fuel Cut Defencer
order i installed with results
Ive been running just the 67mm turbo on it the whole time with everything else stock and has run just fine. Decided to do some upgrades and stuck the SAFC on and the fuel pump and injectors. Started it up and ran 10.5 A/F. Threw on thet fuel pressure regulator with the adapter from driftmotion so i could install the Regulator in the stock location. Set it to 40psi and started it black smoke everywhere. Still running 10.5. Everyone was saying that i needed to get the 2JZ injector resistor to to moderate the injector resistor voltage. Got that and installled it yesterday morning. Still runs Rich, idles at 500rpm and sounds like its camming and black smoke.
Does it sound like a problem or just need to be tuned?
Could i have everything hooked up right?
NGK plugs
