88supramaniac;1328662 said:
ok so i have been driving my car for the past week now and for some weird reason the meter goes all the way up when you drive for a period of time...it tends to suck in the antifreeze too....the radiator empty the next morning....i know its not a bad head gasket because they did it when i bought it....there is also no milkshake or loss of power any way....i did mess around with the needles abit because i put white face gauges and it just seems odd..i am running a n?a fan with no shroud can that be that problem?? im really confused guys..also there is no thermostat because of precautionius reasons...i took it out because of the overheating problem?? help there is also smoke coming from the sides of the radaitor but it flows really good?? any guesses
Ill play nice today.
1. OEM gauge reads temp in the red.
2. You removed the needles on the gauges to put in overlays.
3. Loss of coolant
4. No fluid mixing
5. N/A fan
without shroud on a turbo.
6. No thermostat at all
7. Getting steam from the radiator
8. Never rule out BHG on a 7M.
First you removed the t-stat and so there is no longer a gasket at that location, so the system can leak there now. Also you car works way to hard to get to op temp if it ever does.
Your gauge is wortless because its reading steam not coolant as your pushing it out.
No fan shroud makes the fan far less effective at pulling air through the radiator, thus not good.
Seeing steam from the rad area, either it is leaking (pinhole)or the overflow is pushing out coolant.
What you should do: Replace radiator cap and T-stat & gasket with new oem. Check for hose leaks, loose clamps, blown radiator, and do a block test to check for exhaust gasses in the coolant. Get Turbo fan, get new shroud, and probably fix your BHG.
