Car overheating and radiator light on
Bri7man
"Yeah! Take the lemons.."
Jul 17, 2009
580
Torrance, CA
Dopamine;1426034 said:
I basically replaced everything - thermostat, waterpump, radiator, and radiator cap. However, the only thing left is the hoses, so I'm hoping that's the cause of the over heating at high speeds problem. Thanks.
I'm pretty sure you're hoses are fine squishy or not but replacing them is always good.
It sounds like a bhg man. Is there any white smoke at all on startup?
If it boils down to it hit me up and we can plan a tear down on a weekend in my garage. HKS mhg and a resurface.
I feel bad dude your trying real hard and it shows and I'd hate to see you sell it. Supra's are by far the most bad ass car out there imho.
I know its not possible for you to do this at you're aptt so I'd be glad to help bro.
lmk
Edit,
Forgot... I have a block tester from napa with dye. It'd tell if you have a leak or not for sure.
Dopamine
Cali
Yea I'm going to replace the radiator hoses, the o ring for the cps, and those sensors i got from you. If those don't do it, then I'll hit you up. There's no white smoke at all, but I do see some smoke coming from around the cps. It might be my power steering fluid or something since it's leaking...
For sure thought I'll let you know!
Bri7man
Jul 17, 2009
580
Torrance, CA
The smoke is the oil from the leaky cps hitting your exhaust manifold. Mine does the same thing but I have the kit to rebuild it like I showed ya cost me about 60 bucks including gear+dowel,bearing, O-ring, and seal.
Try the O-ring first $5 could fix it. I'm just going the xtra mile.
None of that is related to you're overheating problems though.
GL bro
soc chaos
Oklahoma
Well I switched out my lower hose, flushed the system, new rad cap, another new thermostat and new coolant and well I just seem to be going backwards because now I overheat just sitting there at idle! Hopefully its just your lower hose Dopamine.
What should the temp difference be between the upper hose and the lower hose? Because my top hose is decently hot/warm nothing to crazy but my lower hose is cold I dont feel any amount of heat. Now I know thats what radiators are supposed to do but still I would imagine some sort of heat in it still.
Dopamine
Cali
Yea, I'm having the same problem; my car starts to overheat if I stay in idle too long. And I'm still waiting for my lower radiator hose to come in. I noticed a bulge right after the connection to the radiator.
As for the temperature, the top hose was super hot and the bottom was hot. I'm starting to think maybe a BHG, but the only symptom I'm getting is the slight overheating. No milkshake, no smoke, no bubbling from inside the radiator, coolant level is consistent, oil level is consistent, no contamination, no milk-grey ring in radiator cap, the only symptom I'm getting is a slight overheating.
Anyways, after I'm done with my mid-terms and tests, I'm going to take it over to a friend's house to see what's really up (if you're reading this let me know what day is good after this week).
Bri7man
Jul 17, 2009
580
Torrance, CA
Friday or Sat would be good, I can at least use my block tester to see if it's a bhg or not, then go from there.
Be careful in the meantime. Don't let it get too hot because then that could lead to head warpage which is no bueno at all.
Carpool or use a relative's/friends car if you can.
paradox616
472
Melbourne, Australia
you could stop guessing and get a hydrocarbon test done, i had overheating issues, turned out to be a blown head gasket, hydro carbon test will tell you if any combustion gasses are entering the coolant system. from memory it cost me $20 and took a whole 5 minutes.
soc chaos
Oklahoma
Well the whole problem with me is that I live in this wonderfully crappy state of Oklahoma for the time being and most likely no one in a 50+ mile radius probably knows how/has the stuff to do any type of advanced test be it hydro carbon, leak down, or compression! So pretty much I just have to go down the list but it really needs all this stuff to be replaced anyway
paradox616
472
we even have the equipment in the bush town i lived in down here in Australia, go ask a few workshops I'm sure you'll find someone that can perform the test for you, or buy the tester.
soc chaos
Oklahoma
Thanks for the link. Granted at this point in time if the radiator doesnt fix it it will be narrowed down to one of two things. Electrical connection or bhg.
ZoomZoomZoom
On the road again..
Dec 9, 2007
443
KY
Or malfunctioning water pump. Mine was working, but not well, causing the car to overheat when under stress.
S.A. supra
2,405
Buda, Texas
Sounds like a blown head gasket. thats what mine did it ran fine idled perfect. the problem came when i parked it. After running it I would park it. It would get Little hot and then would boil over through the reservoir. The coolant would be orange. the bhg would pressurize the system and it would pour out the reservoir. They say that there is a kit that you can buy that you can check for exhaust gases in your coolant. i've never used it. Good luck finding your problem.
soc chaos
Oklahoma
well as to an update I now have the new radiator in and still overheating! Since the water pump is not all to hard to remove and such I took the one off the old motor I have and the one that was on the motor I have in the car and well the one in the car is looser then the other one. The interior unit can be turned with my thumb and index rather easily while the other one I really have to crank it. So hopefully it ends up being that and not one of the two other harder problems!
OK so it has been none of the previous stuff!!!! Its the latter of the last two things I had as options wiring or bhg well I just pulled the temp sending wire off and jiggled it and flipped it around and low and behold no over heat!!! I call shenanigans!!! Dopamine if you dont have a bhg try flipping/messing around with the heat sending wire!
soc chaos
Oklahoma
I dont see the reply of which is asking where the wire is but I will say it anyway! It is located under the green pigtail near the therm stat housing!
Dopamine
Cali
I finally got my car up to start again, and it's still overheating. I also got it compression tested and got 145 on all cylinders. The previous owner told me it was rebuilt so maybe he wasn't lying about that.
Dopamine
Cali
I forgot to mention that my radiator light is no longer on. Also I already replaced with another fan and clutch that's in good working condition.
I also have a partial fan shroud, but I doubt that is the reason why my car is overheating.
airhead04
1,489
Lima, Ohio, United States
Ok, so I read the 4 pages, and youve replaced alot of stuff, so....did you burp the system when replacing the coolant? May be dumb question but people forget to do little things like that.
