Car overheated..whats this part?
sharpknife88
14
Scottsdale, AZ
hey how you doin guys!
Im just wondering what is this part(picture attached),my car started overheating today because the hose connected to that part just fell off.That part was rusted where the hose is connected and their is no way i can plug it back in again. Coolant was going out from that hose and thats what caused the car to overheat..Your help will be highly appreciated. Thanks
strippedsup87
94
Murrieta ca
Thats the heater control valve(for lack of a better term)...it is what lets the coolant get to the heater core for heating the interior. PM
heater core bypass valve. when you turn on your heat it opens and lets hot coolant go threw the heater core. you can bypass the heater core for temp until you get a new one or look in the for sale section or junkyards.
super.secret.supra.club
1,304
San Diego, CA
hvyman;1260815 said:
heater core bypass valve. When you turn on your heat it opens and lets hot coolant go threw the heater core. You can bypass the heater core for temp until you get a new one or look in the for sale section or junkyards.
fail!!
sharpknife88
14
Scottsdale, AZ
Ok thank you so much guys..And sorry i didnt introduce myself to this awesome forum..My name is Tarik Kawa,i currently live in scottsdale arizona and been owning this 1987 supra turbo for like 5 months..btw what does it mean to bypass the heater core for temp..Thank you
sharpknife88
14
Scottsdale, AZ
Oh yeah i just searched the forum about bypassing the heat control valve but i still donno how to do it..Can you please tell me how to bypass it until i get another one..thanks
strippedsup87
94
Murrieta ca
the two hose ends that connect to the heater control valve can be hooked together(bypassing the valve) for now until you can get another one....
sharpknife88
14
Scottsdale, AZ
Ok guys i think im going to stick with the bypass solution, but can you please tell with what should i connect the two hoses with, and what kinda material should it be..i know that im asking too many questions but i wanna make sure im doing everything right..thanx for your help guys??..btw i searched the forum but i couldnt find that much help on this problem
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
Just go to home depot and get a brass coupler the right diameter. The heater valve is a 90 degree elbo, so you might want to get a 90 degree fitting to avoid twisting the hoses weirdly.
I am a local Arizonian as well. I dont know if you have seen: http://azsupracentral.com/forums/index.php?
But it is a pretty active forum and the guys are nice. I have had my heater valve bypassed for a while now, and there are no issues. There is a flapper door inside the cab that directs air in the ducts, and there is a door that blocks the heater core when the heat is off, so you dont have to worry about getting hot air in the vents when the heat is off.
If you need any help with anything hit me up im always willing to help out.
sharpknife88
14
Scottsdale, AZ
Ok thats awesome bro,ill just go to home depot tomorrow morning and get the brass coupler then..ohh yeah i know that site, the people their are kool and helpful..ok ill let you know if the coupler works out as soon as i get it..thank you
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
why not just get a piece of heater hose and loop it and that way you'll have a new hose in there? obvisouly it broke/ripped for a reason...
might wanna take a look at your other coolant lines.
and btw, an autoparts store sells fittings MADE for coolant... i dont know if i would want another metal like brass to be in my coolant system.
Moy
It's broken...
Aug 6, 2008
2,432
Beach Park, IL
Bah, why bypass when zip-ties are your friend? I have the temp control in the car at 85, had to push the plunger all the way up, then zip-tie it in that position.
Now I have heat! :biglaugh:
sharpknife88
14
Scottsdale, AZ
Sorry Rennat but i didnt understand what u meant when u said to get a piece of heater hose and loop it, can you please explain what you meant?..and btw the only reason the hose got loose is because the heater control valve was rusted where it connected to the hose..So guys, do you think if i used the brass coupler it would have any affects on my coolent system?
