Car jerks when accelerting
crazysk8er1010
14
OC
Supra has been jerking when accelerating hard or quickly. If I keep my foot on the gas pedal and very slowly gain speed, the jerking won't happen. This also happens intermittently and regardless of what gear I'm in. I've already replaced the fuel pump and fuel filter.
Any other ideas?
87 Supra N/A, everything stock
Thanks
crazysk8er1010
14
OC
Suprapowaz!(2);2033324 said:
Change fluids in the pumpkin? Auto or manual? You're not giving us enough details of your setup.
It's a 87 Supra non turbo, manual setup W58, everything is all stock. I havent changed the differential fluid since I've had the car. I also don't hear the differential making any noises. Could bad differential fluid cause jerking?
8,900
This is usually enrichment. That doesn't mean a pump is bad.
This is almost never enrichment. This is often ignition. You might have two problems. But I can not see it from here.
