so my 87 it's burning oil randomly but not a lot. it doesn't do it right after start up like valve stems would sometimes it does on start up some times it does on accel and sometimes it does on decel and it does on boost it's doesnt sound like valve stems but could be a valve? also when vaccum is at like negative 15 or so wen I'm just barely givving it throttle to cruise it has a jerk like a hesitation similar to a boost leak but at idle the vaccum is right where it's supposed to be I'm at -18 -19 at idle I'm going to do a compression test and lak down but I was wondering what you guys opinions were before I start checking and give me ideas on things I should check
also yesterday I was letting it idle everything already warmed up and it randomly stated missing then dropped to about 300-400 rpms and went back to normal only time is ever done that
