car dies at idle help?
917mgte
115
butte mt
car runes fine at idle when cold but as soon as it gets hot it idles at 400 rpms and dies out when reaching idle when driving.
IwantMKIII
WVU MAEngineering
Jun 12, 2007
2,480
Perkasie, PA
check the small filter (or whatever it is) behind the ISC and clean it. Make sure ISC is working properly (should click after you turn off the car, also check resistance).
thevork
ShoarmaTeam Member
before doing that, it's worht trying to disconnect the plug from the ICSV while the car is running good at cold idle.
If the car keeps idling just fine when it gets warm it's your icsv. If it still stalls it's probably something else.
Did you check for codes yet ?
917mgte
115
butte mt
i haven't had alot of time to work on it just yet but hopefully be able to check everything out this week. i will try to clean out the throttle body bore and pcv check the coils and hopefully i can figure something out thanks for the help
