I've been having a problem with my supra for sometime now. It starts up fine when its cold but when I start it up when the car is warm it will idle poorly, want to die, and has a lack of power. After I drive it around a bit, the problem will lessen. The car almost always has no bottom end power but when I hit around 4k rpm, the car pulls great. It started on my factory engine and after replacing the engine, the same problem existed. I've replaced the dist, plugs, and tested numerous items: coil, wires, afm, lots of sensors, etc. anyone ever have similar problems? suggestions?
