Can someone tell me what this part is called?
stealth
San Francisco
Take a look at the pic. The hose off the back of the block goes into this part attached to the firewall. This isn't my motor either.
supra90turbo
shaeff is FTMFW!
33
MA, 01440
Not really ouch.
The only time the valve is closed is when the AC is on.
It's usually open and circulating hot water through the core.
rumptis
나는 제프가 당신을 사랑
Aug 16, 2005
814
North Vernon, IN
supra90turbo said:
Not really ouch.
sorry but you are wrong.
It should always be closed unless you have the heat on, otherwise in the middle of summer you would always be heating your car unless you have the AC on.
You can get rid of it if you wish but you will not be happy with the results when it gets hot out.
supra90turbo
shaeff is FTMFW!
33
MA, 01440
Really? I always read that it was always open. Guess not.
Doward
4,245
Alachua, FL
Heater valve is only closed if the inside Climate Control is set to 65 degrees.
The air mix control servo motor is what keeps you from always running hot inside the car, with the coolant valve open.
What the hell - just to avoid future confusion -
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?Section=AC&Page=41
supra90turbo is correct.
Running without the valve would do little to change the internal temp of the car - you'd just not have that supra ice cold AC when you set it to max cool (65 degrees)
rumptis
나는 제프가 당신을 사랑
Aug 16, 2005
814
North Vernon, IN
so if its 105 in your car and you have the thing set to 66 degrees its going to be flowing hot water through your heater core?
Doward
4,245
Alachua, FL
Eh, it's cool. Go check out any old (pre '80) GM - nobody heard of a heater valve then. ;) Hell, Dodge ran without one in their trucks until like '99, IIRC.
Just because hot coolant is running through your heater core, does not mean the air flowing over your heater core is coming into the passenger compartment.
