Can I use 2jzge OEM Motor brackets into a 91MK3
nightrider760
219
escondido , tijuana
I was wondering if you can use OEm Motor brackets into the mk3 ??? Has anyone done it before. The reason why iam asking is because my bufget does not allows me to buy aftermarket Motor Brackets.
kneedragger85
363
Boulder, CO
There are zero factory 2JZ brackets that will fit into a MKIII. If you don't want to buy aftermarket, then find a set of JZA70 1JZ brackets to use instead.
empera
Authorized Vendor
Philly.
ifyouaint1sturlast;1755793 said:
If you could, why would anyone buy the aftermarket/custom ones?
dont be a douche
correct, of course the 2jz brackets arent going to fit into the mk3 chassis but the 1jz/jza brackets will. like stated above.
