Can I run a radiator from an 89-90 Cressida safely in my supra?
xXSupramanXx
Drifter
Mar 12, 2008
149
Dayton
As the title says, I was wondering if it would be ok for me to run a radiator out of an 89-90 cressida with a 7M safely in my 7mgte swapped supra with basic mods (exhaust, intercooler, 9psi). I. Called my local parts store to check and see if the radiators from both cars had the same part numbers and they did not. I thought I'd ask you guys on the forum to be sure. Thanks in advance.
-Chris
sogi99
115
Elk Grove, CA
-Chris
no the mounting for the bottom they are not the same but the size and width are the same. I test fitted one of those at the junkyard and found they don't mount the same on the bottom.
xXSupramanXx
Drifter
Mar 12, 2008
149
Dayton
Oh ok thanks for the info. I saw a cressida at a junkyard and was in need of a rad so I figured I'd pick it up, but now I know better.
rayall01
901
Westfield, ma
Better off going with a new radiator anyway, No matter how good a used one looks on the outside, it could be trash on the inside.
gofastgeorge
944
Texas
And I don't think they are the same size.
I had one of each sitting next to each other in the garage for 6 months,
and one was taller than the other by a good inch.
