7mgte. I have one factory sensor (8961530020) in the front and a 1jz sensor (8961520030) in the back. only mixed them because I got the 1jz sensor brand new for free from a friend and just bought the connector for $10 and soldered it in. done the complete rewire with rg58 cable. soldered all connections. theyre solid. grounded to the firewall behind the glovebox. it takes longer to show up now but still throw code 52. wondering if the problem is because I mixed sensors or if maybe the remaining factory sensor is bad. I was told the sensors themselves are identical just with a different connector.
