Reason I'm asking is because I'm trying to pin-point the issues. Car will start and idle great but when driving I get the classic boost leak symptoms at random...Car gets jerky/power cuts out and the cel flashes for a second, then it will go off and it builds and holds power fine again for awhile. This happens at complete random times though not just in boost. I have a code 11 which is intermittent ground to ecu. I've checked and re-checked grounds, and replaced the efi relay cuz I had a new one anyway.
My vf will be right at 2.2-2.5 idle for a few seconds after start up then it will drop to 0.0-0.2 and stay there even while driving with varying throttle amounts. So I don't really want to be driving it until I figure this out. Also, when I get the cel while driving my vf shoots up all over the place. I guess the question I'm asking is am I chasing a boost leak or could the code 11 be contributing to the problems? Im picking up my boost leak tester from the shop tomorrow and will test that but just wanted opinions on that code 11.
