Cams
corylee316
until it goes boom
Aug 17, 2006
125
Moscow, IA
I've done some searching off site and have not been able to come up with anything for the NA. Do you have to get custom grinds or am I just not hitting the right sites. I'm thinking future project and want to know what kind of options that I might have. Thanks in advance.
corylee316
until it goes boom
Aug 17, 2006
125
Moscow, IA
So are the regrinds a stock cam or are they a different grind. I know that custom cams can be made but they aren't cheap.
Sawbladz
1,727
Oshawa, ON, CA
re-grinds use your cams as a starting point and reduce the base circle to give the cam a different profile. Search, you will find excellent information on this site, much better than I could ever explain.
935motorsports
San Diego, CA
A regrind is taking your original cam and "re-grinding it" to your specifications.
This makes the cam area smaller, so lash caps are required under the buckets to make up the difference.
You can send in your cams to many cam companies for this.
We also sell cams already done for $400 a pair, including the caps.
corylee316
until it goes boom
Aug 17, 2006
125
Moscow, IA
What are the specs on them. I want to know what is out there before I do any thing with my car. I have an idea of where I want to go but I also want to know what I'm getting myself into.
corylee316
until it goes boom
Aug 17, 2006
125
Moscow, IA
I have read lots of posts on cams. Most of them have the word cam in them and have not bearing on what I am looking for.
If I wanted to just lay out money I would have two new cams cutom ground.
corylee316
until it goes boom
Aug 17, 2006
125
Moscow, IA
Where did you find these and what are the specs. I am curious b/c I am wanting to go faster and as far as NA goes cams and some head work are about it
supra90turbo
shaeff is FTMFW!
MA, 01440
supraracer49 said:
My dad'a a master technican for Toyota and He did head work and a TRD cam in my truck. If your trying to get a lot of power out of an Na then these aren't the way to go. They are slightly modded but still legal for emissions in all 50 states. They get you more power but mostly at high RPMs. The prices are what he can get them for but as far as the genral public I have no idea on the prices. If you want some real power go with HKS but you will probably need computer work and different ingition.
Come on... this isn't a 22r. The cams available for 7M's are few and far between. TRD made some, they were Grp.A cams and think about spending $1000 for the pair if you're lucky.
HKS, again, made cams. But again, look to spend about the same as TRD.
Computer work and different ignition? ....
Regrinds are the way to go today. Either that or get a set of Brian Crower cams from the HPF group buy.
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
:bigthumb:
but jesus, whats happening? this whole thread has just been a shitload of misinformation, save a few posts that said "use the search button"
Ma70.Ent
1,871
NJ
Clip said:
:bigthumb:
Well, I was right about there being no current cams for the N/A, so yeah. :icon_razz
7MA61
7MA61
Aug 27, 2006
98
Sydney
I am going to run the Brian Crower 272 and 9.52mm lift cams in my NA will see how they go, yes I know they are designed for a turbo engine.
TODA and Ted's are one of the few that still manufacture cams for 7mge's but they want about $1,000 Australia or $750 US a piece which is a joke.
