Cams ok, vacuum help needed
Chaingun
285
Mooreland OK
lol yeah 49 cents each at tractor supply, conicidentally the only place in the area that has high grade metric bolts go figure, rather than risk it i'm replacing them all, should have wiring done today including reverse light rewire from the tranny swap, and the knock sensor rewire too.
Chaingun
285
Mooreland OK
ok so apparently iam indeed a retard, i had taken pictures of all of my vacuum and wiring before tearing it down, yet apparently i managed to need to format my iPhone so i lost it all, in any case, i'm good on everything but one bit of vacuum that seems very off, and i can't find it in the diagrams i've located on the site. I know i'm a retard, but i just need to know where these hoses run:GEDC0097-2-1024x768.jpg also there appears to be a vacuum bung under the #2 intake runner, is this part of the solution or another problem? as always help is appreciated, and any pics would probably save my butt
EDIT! 1 &2 are the fuel pressure regulator VSV, still need help with the others
mkiiichip
1,434
WI
#3 goes to the BOV.
There is another hardline\bracket that bolts between two intake runners before it goes to the hardlines bolted to the 3000 pipe. Then to the BOV itself.
8,900
Chaingun;1676660 said:
and i can't find it in the diagrams i've located on the site. I know i'm a retard, but i just need to know where these hoses run:View attachment 48841
Did you get number 3 from Chip yet? Here is a vacuum schematic that many people don't see.
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?Section=EC&P=4
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?Section=EC&P=6
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?S=FI&P=3
Chaingun
285
Mooreland OK
EDIT i'm a complete tard and this has just dawned on me lol, i found the hardline in question in the parts catolog and i can see where it should go, just a matter of hooking it up, thanks guys so much, my baby has been in the garage for WAY too long, and i wanna hear here run again
Chaingun
285
Mooreland OK
well it's all back together, but i can't get her to spark, I'm going to check cps wiring tomorrow any thing else i should look out for?
