Is there any way to adjust the air gap on our cam sensors?
88YotaTurbo New Member Feb 26, 2006 658 0 0 42 Wolcott, Ct. Sep 14, 2007 #1 Is there any way to adjust the air gap on our cam sensors?
Jason T JZS161 Aristo TT Mar 30, 2005 98 0 0 55 Auckland New Zealand..Aotearoa Sep 14, 2007 #3 88YotaTurbo said: Is there any way to adjust the air gap on our cam sensors? Click to expand... http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?S=IG&P=16 Check the plug coming out of the CPS any rotted wires looking green around the contacts then time to resolder or hard wire
88YotaTurbo New Member Feb 26, 2006 658 0 0 42 Wolcott, Ct. Sep 14, 2007 #4 are the actually cam pickups adjustable and how? I have not opened a cam sensor yet too see.
I IJ. Grumpy Old Man Mar 30, 2005 38,728 1 0 64 I come from a land down under Sep 14, 2007 #5 IJ. said: Yes. Click to expand... ja oui ναι si sim да Ok it comes out the same in 7 languages I'm not sure if you understand any of these......
Poodles I play with fire Jul 22, 2006 16,757 5 0 45 Fort Worth, TX Sep 14, 2007 #6 living up to your "Grumpy Old Man" title? :biglaugh: OP: someone posted the actual directions for setting the air gap, click the link...
88YotaTurbo New Member Feb 26, 2006 658 0 0 42 Wolcott, Ct. Sep 15, 2007 #7 thank you i guess. I will check them tomorrow thank you.
