I have been having an intermittent air conditioning problem.
Let me start off by saying I running a 1j and when the a/c is turned on the idle up works as it should
Our temps here in Houston have just been hot, but pretty consistently within a couple degrees from day to day. Well, with the air on, the regulator temps fluctuate from 60* to 40*. This is going down the highway at 60mph+.
So I read the manual, and started to check things out.
Found two things that struck me as odd.
The first being that when the a/c is on, the sight glass stays pretty clear, but if you turn the a/c off, 20-30 seconds later the freon with what looks like it in it's liquid state bubbles a little and then drains from the sight glass. So much that I can see freon draining from the tube to the right of the sight glass. I don't think the manual ever mentions being able to see the freon drain to the bottom of the rec/drier in the sight glass.
The second being, when I crack the throttle quickly, the a/c clutch disengages completely, but if I slowly crack the throttle it stays engaged.
I just discovered these two problems, but while doing so in my garage, the a/c on was blowing a solid 45*-50*.
I am wondering if I have a big air pocket in it or that maybe these two problems are related.
One more thing, my a/c will cycle.
Any thoughts??
Thanks
Wayne
Any thoughts??
Thanks
Wayne
