calling all GM experts
kabanimk3supra
kabanimk3supra
Apr 11, 2007
511
oklahoma
I have a 95 chevy 1500 with a 350 motor
problem: the temperature gauge does not work.
I have tried to wiggle the temp. sensor wire because it looks very old and brittle. (to see if the gauge would jump around)
that did nothing.
question: what is the first thing that usually goes?
where or what should I be looking(at)?
I'm thinking it's the sensor, but I'm not sure and don't want to waste money replacing parts I don't need to replace.
thanks
monkihead
driven to thrill
Jul 23, 2005
93
texas
pull sensor off intake housing and submerge in 200 degree water. if gauge doesn't move sensor is faulty. the temp gauge usually doesn't go out. However, if you run a jumper wire on the harness it should make the gauge flicker(just to double check gauge). your looking at a $20 part.
kabanimk3supra
kabanimk3supra
Apr 11, 2007
511
oklahoma
what do I run that jumper wire to?
I'm still a bit confused.
please elaborate.
Mk3runner
2,033
Nor Cal
Basically wanna ground the wire to make it jump on gauge. It should peg out tho instead of flicker... It's been a long whilesince I had to do it. Sensors are dirt cheap.
kabanimk3supra
kabanimk3supra
Apr 11, 2007
511
oklahoma
I jumped it and it pegged out. so my sensor is bad right?
the only thing is the wiring looks horrid, I'm thinking it may have something to do with that as well.
thanks for the help guys
