Hello all,
I recently went to have my car smogged at a test only station and had some enlightening results.
First :
I have no codes. Checked before and after the smog test.
Second:
I'm running pig rich, which I believe is causing very high Carbon Monoxide and Hydrocarbon readings. As far as I can tell the car idles and drives fine. I am guessing I'm losing some power, but there is no hesitation, etc.
My Plan:
I first plan to check my O2 sensor here: http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?S=FI&P=119
Does anyone have any other/better suggestions? Does anyone know why I would be running so rich without any codes appearing? I also suspect the Air/fuel regulator, and my O2 as a hunch, but have no evidence to back it up.
EDIT: Fixed image.
EDIT2: I recently disconnected and installed a new filter. If I remember correctly, the ECU needs to "relearn" after the battery is disconnected?? Could this be a potential contributor? Please note, there were no codes before the battery disconnection either.
First :
Second:
My Plan:
EDIT: Fixed image.
