7M-GTE said:I used a steel braided line... but it came with my afpr install kit...
jdub said:I went from the fuel junction on the block direct to the fuel rail, removing the FPD all together. AN-6 line & fittings; the fuel rail fitting is 14x1.50 mm AN-6...I think the junction fitting is the same, but to be honest, I can't remember. The hose end on the fuel rail is a 120 deg AN-6; the one on the fuel junction hose end is 90 deg AN-6. Here's a couple of pics...sorry the one is a bit blurry, but you get the idea.
89MkIII said:Thanks for the pics. Alright, so if I have this right, everything I need to correctly install a AFPR is basically supplied w/ the LIPP kit I got with the AFPR? Sorry for all the questions, I just want to make sure I have all my ducks in a row when my mechanic friend helps me w/ this install.
89MkIII said:Yes, my fuel pump will be upgraded at the same time. So if I'm understanding correctly, the two fuel lines connected to the J-tube (illustrated in my original picture) will be replaced w/ a braided line in my afpr kit.
89MkIII said:Yes, my fuel pump will be upgraded at the same time. So if I'm understanding correctly, the two fuel lines connected to the J-tube (illustrated in my original picture) will be entirely replaced and/or bypassed w/ a braided line in my afpr kit that goes from the AFPR to the fuel return line.
I'll put a pic of under the lower intake so you can see what I did under there...89MkIII said:AWESOME..... Really appreciate it! And yes, I bought everything from Supra Sport, the aeromotive unit and the LIPP kit.
