installed vpc/safc, afpr
now i am blowing gaint clouds of black smoke
i know that i am running rich. an understatement for the amount of smoke
my na-t starting and idles but after giving it some gas it stalls out
tonight i am going to set the fuel pressure to 20ish and see how much smoke is still puring out
i believe that the tps set screw has been readjusted by someone other than me and its now stuck. i think this is what is causing the staling and the extremely low idle 450-550, but when i get it gas it is very strong now breaking up or misfiring
also tonight i am going to get it to idle better and not smoke so much
i also have a problem that after my vpc/safc install i have no fuel pump
but when i jump it in the diagnostic block i have pressure steady
any ideas what could be causing this
while running sometimes i have a blinking cel but when i check for codes i have none and when running smooth no blinking cel, but at idle blinking cel . could this be the knock sensor
and would a burnt o2 sensor cause a running rich problem no wideband yet
