Budget brembo front brakes
SBM713
222
Georgia
Then ill have brembos on all 4 corners and be boss status lmao I wish
Sent from my SAMSUNG-SGH-I337 using Tapatalk
Dylan JZ
一番 King
Oct 18, 2007
2,220
湾岸せん
My Evo setup was right around $600 with used calipers, stoptech rotors, Gr10 hardware, and SS lines. So add that to your setup and I'm still seeing around $1200. More if you want reman calipers.
SBM713
222
Georgia
See I was trying to do that and a guy was supposed to keep me posted on brackets but he didnt sobi took it into my own hands no machine work just bolt on brembos with the right off the shelf parts.. and I found that there are some Mercedes Benz that come with brembos that have the same bolt alignment as our supras just need a spacer machined to fit but I dont have a machinist as hand lol... and im only doing this cause I refused to pay for the azp wilwood kit lol my cars a project and the calipers are siezed from sitting so this is my nickle and dime project... how much did it cost you for your rear brembo set up
SBM713
222
Georgia
So you have willwoods and brembos? I want a matched pair
Dylan JZ
一番 King
Oct 18, 2007
2,220
湾岸せん
Correct.
I'd love a full Brembo setup, but it's a lot more time and $ just to say they match. There are Chrysler Brembos that are basically bolt on 6pot 14" brakes, but the bias isn't too favorable even with the Evo rears. My bias with the Wilwood fronts is pretty decent though.
SBM713
222
Georgia
See the beautiful part is mustang guys would pay a premium for my calipers as theyre the same as cobra rs
5
- You're using used calipers (at least rebuild them).
- Cobra R brakes are not full bolt on as they're larger than the normal Cobra brakes.
- The rotors won't work as they don't match the calipers.
- Brembos are notorious for striped hardware as they're pretty soft aluminum (all brembos are NOT created equal).
- The expensive part of the arz setup is the 2 piece rotor which is where you drop the weight. The arz setup is LIGHTER than the factory setup on our cars, while if you went this way, you'd be heavier because of the huge single piece rotor.
SBM713
222
Georgia
Cobra r brakes are full bolt on for 94-04 cobras.... therefore with cobra rotors and cobra brackets I should be in the good
5
What wheels are you going to run? Going to have to be at least 17's (if not 18's) and you'll need to clear the caliper which will be the harder part.
SBM713
222
Georgia
Be 18s probably fr500 wheels that are on my cobra right now
SlimLim
170
Australia
I hate to break it to you, but i bought the ford focus brembo calipers thinking it would be a direct bolt on to the mustang cobra brackets. Well, they don't fit. The pistons on the mounting side do not clear the holes. I'm going through the pin of making my own brackets now, as the two piece rotors i bought were $750 on sale. So I'm going to make it work.
SBM713
222
Georgia
Slim post pics or text some to 7069947206 I dont understand what aer the part numbers of your calipers
SBM713
222
Georgia
The waybi figure it is the m2300b calipers bolt directly on a 94-04 calipers stock just a banjo bolt needed so if I get a cobra 13 inch stock rotor it has to fit...
SlimLim
170
Australia
No, it doesn't because the mustang cobra calipers are 2 pot on one side only, sliding on the other. The mounting side is sits flat on to the bracket because the pistons do not interfere.
I live in Australia, i'm not calling you.
SBM713
222
Georgia
Lol no the cobra (pbr) brake caliper mounting bracket that houses the slide pins bolt to the driftmotion bracket where your caliper would bolt to it whats your caliper part number
SBM713
222
Georgia
Either way ill try it and if that dont work ill take the calipers off my cobra and put brembos on my cobra
