BSV and VSV
Blackdawg
Taco Soup..my rides
Oct 12, 2010
247
Wyoming
Hey guys, so i deleted my EGR on my rebuild. I am wondering to those how have done that, what did you use to get rid of the BSV? I know a lot of ppl just plug the hole..but with what?
Second. can some one please clarify what the VSVs do and if they are needed??
Thanks!
IBoughtASupra
4,455
Queens, NY
VSVs are for the canister.
BSV valve can get any plug but it is BSPT, British Pipe Thread. NPT is different. If you know a good TIG welder, they can plug it and weld it shut.
metaphysico
Mad Scientist
Jan 2, 2008
428
Gainesville, Georgia
I just stuck a spare temp sensor in the hole. Not the best looking but will work. You might be able to drill it over and tap it to a larger npt thread then get an earls plug for it.
metaphysico
Mad Scientist
Jan 2, 2008
428
Hahaha BVSV = Bimetalic vacuum switching valve (switched on by temperature), VSV= vacuum switching valve (switched on by power and ground being applied). I am using a signal from my electric fan temp switch to turn on a vsv to run through the canister.
Blackdawg
Taco Soup..my rides
Oct 12, 2010
247
Wyoming
Ahh my bad haha
Well cool so bye bye VSVs!
And thanks for the thread info! i woulda screwed that one up for sure..
metaphysico
Mad Scientist
Jan 2, 2008
428
One of those vsv's is a fuel pressure up vsv so you would want to have it I would figure, not sure what difference it would make to run straight manifold vacuum to it. If you dont have an egr that one is not needed then.
