broken connectors
122578
just takes time
Dec 16, 2005
n.c.
I know I'm not the only one that has the old bridle wiring harness problem so i was wondering what everyone does when the oem connector finally crumbles (stopping short of replacing the entire harness). I mostly splice mine together when plugs are not necessary but now the tps connector broke. Is there any sites that offer replacement connectors?
Jeff Lange
Administrator
4,919
4
Sunnyvale, CA
jefflange.ca
A lot of connectors can be ordered from Toyota if you need them. Toyota also supplies the terminals, but they only come already on a splice of wire, if you want just the terminals themselves, Dr. Tweak (Phoenix Tuning) sells them as well.
Throttle Position Sensor:
Plastic Housing: 90980-10378
Terminals with 160mm Wire: 82998-12120 (Qty: 4)
Jeff
