my dd is a '95 corolla and i replaced the brake pads about a month ago. every now and then there will be a pulsing grinding noise that the brakes make. its only on the drivers side i believe, you can see some lines on the rotor where the grinding is happening. i took the pads out and wiped them off and put it back together. it was ok when i drove it after but this morning it made the noise again. i don't know what the deal is. any help is appreciated.
-Nate
-Nate
