BRAKE LIGHTS NOT WORKING..
huntin5L
Niles, IL
So my brake lights are not working, my 3 brake light (wing) works, but the brake lights are not working when i step on the brake. I looked for a switch under the brake pedal and there is nothing there. I checked my 20 amp fuses and they are all fine. Is this a blown lamp failure box? I took it out and took it apart and everything looked real clean and all solder points were fine. I swapped out the bulbs and it is still not working. My turn signals work and my rear tails work when my headlights come on if that helps. It is only when I step on my brake that i am getting nothing. lmk.
veedubin
Official SM Decals
study the wiring diagram for the brake light ckt. Just going out on a limb here, and with out seeing the diagram myself.... if the feed for all 3 brk lights come out of the lamp failure module, i'de say there is probably a brken wire or a broken splice somewere after the lamp module.
cuel
1,536
Baytown, Texas
Sounds like the failure box, and not the brake light switch, as you said the 3rd light is still working.
Kruso
2J>7M
Jun 9, 2007
34
SugarLand
If the switch near the brake pedal goes out, the lights remain on continously (I'm not talking about exception to the rules which I have yet to witness on any car). If the lights are not working at all, you need to check your fuses, the odds are something is blown. Check both near the driver side kick panel and under the hood.
Kruso
huntin5L
Niles, IL
I can't find any switch by the brake pedal and i stuck my head under there as far as i can go, where is it? I checked all the fuses and they are all fine. Also, what am i checking under the hood, which fuse?
huntin5L
Niles, IL
From the diagrams i saw it is the kick panel on the inside of the car where the 15amp fuse is. I checked all 15 amp fuses and none of them are blown.
huntin5L
Niles, IL
Anyway i installed another used lamp failure box and it works, but the light on my dash is still on for whatever reason i can't figure it out. Ahhh!
probably the wrong failure box...
the N/A failure box will trip the failure light because the LED's 3rd brake light doesn't pull enough amps...
james_9876
Rehabilitation time...
Aug 1, 2007
183
Spartanburg, SC
Okay, I had the same problem!!! There's one wire that comes into the Lamp Failure Box (LFB) from the brake switch to feed the wires. Then two leave to the seperate lights.
What happen to me. Checked everything, wire, bulbs, connectors, everything was fine. So I'm like 'alright, now what?'. So I took the LFB out and took the circuit board out and took my DMM, set it to Ohm's and checked continuity from the pin to the solder. No continuity. Re heated the solder and got continuity.
Cliff notes:
Check the pin to Solder connections on the circuit board in the Lamp Failure Box.
huntin5L
Niles, IL
hmmmm..interesting. I think poodles though may be on to something, because the box i got was a yellow one and mine was white. But, maybe the box is just discolored from age I didn't look at it that closely though.
