Brake light issue
TweeT91109
738
Tampa, Florida, United States
So as stated i'm having a bit of a brake light problem. Its with and 89 MK3, the problem is...when I have the parking light on they work, but when I go to press the brake pedals the lights to not brighten, non of them. I also own a 86 MK3, I put both of the the brake cluster in the 86 and they brighten when I press the brake pedal. So I have been researching a bit and i'm thinking something might be wrong with my "brake sensor". Has anyone had a problem like this. Can anyone give some insight on how to get them working again. And thanks guys.
Also should I try something like this ?
http://www.supramania.com/forums/sh...Bypass-GET-YOUR-TAIL-AND-OR-BRAKE-LIGHTS-BACK!
Personally i wouldnt hack up the cars body harness. I would just get a new sensor if thats the problem.
I would check the brake light sensor tho first which is attached to the pedal.
8,898
Check and see that the brake light switch is plugged in. That is the one on the pedal. You can check to see if it closes with a voltmeter.
