Ok so the other day my brake lights went out and will not light up when pedal is pressed. Signals, reverse lights, and all running lights work.
Fuses are all good, changed brake pedal switch and no luck. Also have changed and checked the dash light circuit board sensor on rear tail light area.
I SOL as of this moment. Any other notorious things that happen electrically to cause this kind of failure or what to check for.
91 Turbo 5-speed
91 Turbo 5-speed
