BOV question
87nasupra
Scotty's Garage
Mar 2, 2006
993
Jacksonville, FLORIDA !
Well, I've been building my engine for the last year. It will have eagle rods , je's coated, arp everything, etc., etc. I will be starting with stock everything on the exterior but upgraded inside the block. Would my stock BOV stand up to the modding after I install 550's, lex, AFPR, maft-pro w/innovate WB ,etc. When should I install a upgraded bov. I've read contradicting threads and would like input. If I upgraded sould I recirculate? Any input is greatly appreciated. Realistic WRHP goal of 400 daily and/or track/weekend driving
kamikazemkiii
1,219
North Carolina
I would upgrade the BOV its seen 20+ years of boost and im sure its tired and probably need something bigger
i kno its better to recirculate on stock ecu but since u have maftpro im thinking it would be ok to have it to atmosphere
TomFraser
my stock blew at 10 psi after 2 days, it would open under boost and cause compressor surge when it should have been open when the throttle closed
I now have the HKS kit that replaces the plastic pipe and goes to the 3000 pipe, and vent to atmosphere
I'm happy :)
87nasupra
Scotty's Garage
Mar 2, 2006
993
I will be starting my modding slow and I figured once I get my piping done and installed in the car I would go ahead and put in my hks and recirculate. I have the innercooler piping done and waiting on my innercooler to get done, but it'll be a few months before the engine is in my car though. I will not be going maft-pro til next year im sure
jdub
Feb 10, 2006
10,730
Valley of the Sun
Keep in mind Tom is running speed density...venting a BOV to atmosphere is not an issue because of that. On the stock system, venting to atmosphere can cause the engine to stall. A good alternative to the stock BOV is the Bosch 110 and recirculate the same as stock.
jdub
Feb 10, 2006
10,730
Valley of the Sun
I've heard the same thing, but never observed personally. A low boost flutter is a heck of a lot better than a stock BOV stuck open or one that causes compressor surge.
