BOV problems....
supramike7m
92 teal-wn turbo
Jan 29, 2006
759
prescott, Arizona
88YotaTurbo said:
i don't think so but keep them fingers crossed. you could always inspect the veins in the compressor wheel. Remover the accordion hose and look for mangled broken fins.
it probably wont have any sever damage like that, but you should feel for shaft play. just get ahold of the wheel inside the compressor housing with your fingers, try to move it side to side, or forward backwards. forward back is bad, side to side not so bad as long as its not a huge amount of play
AaronsSupraMKIII
254
Athens, AL
I will...thanks guys! You guys are all life savers to us new guys. I feel like a freakin idiot for not asking about the venting before now. I checked my turbo a few weeks ago, and the fins looked good and virtually no play any direction on the turbo. I did have some oil in the accordian hose though, so I need to fix up a catch can next.
88YotaTurbo
658
Wolcott, Ct.
Yeah i need cooleeze hard pipes :,( but yeah man you got it right for the oil diag. CATCH CAN FTW. Just added a homemade on myself and I'm inthe process of cleaning intercooler and pipes.
AaronsSupraMKIII
254
Athens, AL
Thanks! I have a set of shaved and black powdercoated cam covers I am going to put on real soon, and change all the hoses and stuff to red. I am going to do a compression check, adjust the lifters, and change the plugs when I change the covers.
supramike7m said:
just keep adjusting it bro, youll get it right. nice engine bay by the way, i love the black cooleze pipes. mine pipes were black as well.
Dunckel
2,949
Spokane, WA
That's what were here for Aaron. So I guess we figured out the bov problem. Your boost pressure issue I'm still a bit cloudy on. Maybe I'm just tired. So you hooked up a MBC, turned up the boost, and still are only hitting 5 or 6psi max?? Is it hooked up correctly?
Look at the fourth post in this link.....http://www.supramania.com/forums/showthread.php?t=22293&highlight=mbc Look like your setup?
Keep us updated on how the adjustment goes. And one more thing. Where the hell do you work this late at night, and are able to be on teh intardnet, and get paid for it?
EDIT: Whoa, whoa, whoa. I just went through this thread again and saw that you had stated you have an ELECTRONIC boost controller. Duh, I must be tired. Nevermind the last half of my post.
supramike7m
92 teal-wn turbo
Jan 29, 2006
759
prescott, Arizona
yes make sure you have it correct. just swap the hoses and see what happens. also most mbc's are shipped at the lowest boost setting. so even if you turn it up a little, it may not even be set the boost level your already at stock, just turn it up a good amount and see what happens, if anything youll hit fuel cut, and youll know. then just slowly turn it down.
EDIT: lol, did the same thing dunkel. still switch the hoses on the boost solenoid, and see if it changes, maybe there just backwards. what kind of ebc is it?
AaronsSupraMKIII
254
Athens, AL
ok I am back. I am now VENTING! YEAH! ok I have a Greddy ProspecII EBC.
I am not sure if it is hooked up right or not. I will try switching the hoses tomorrow. I bought it this way. I have fixed several little thing that added up to a weaker than hell car when I first got it. The guy put a JDM engine and tranny in it, and never could get it right. I guess he got fed up and sold it to me cheap. I am getting there with the car. I hope to get it up there to 500 HP within this next year or so. (If I dont blow it up being stupid) LOL
As for my job, I am shift supervisor over security, so I am setting in an office most of the night, and walking around the plant the rest of the time. It is an easy job.
88YotaTurbo
658
Wolcott, Ct.
You mean you surf on SupraMania and get paid for it you lucky ASS.
supramike7m
92 teal-wn turbo
Jan 29, 2006
759
prescott, Arizona
i would suggest running an extra quart of oil in it, just to be safe. and dont run thick oil, despite what some people say its not better, run as thin as you can.
AaronsSupraMKIII
254
Athens, AL
Yeah! LOL and thank god I found Supramania, it keeps me off EBAY, and keeps some money in my wallet! I am helplessly addicted to Ebay, and need to stay the hell off of it.
AaronsSupraMKIII
254
Athens, AL
I am running a quart over, and I have 5w30 in there. It is pretty thin stuff. What do you use?
Dunckel
2,949
Spokane, WA
Is this the Mike, Aaron and Dunckel show tonight?
And Yota, you can join too.
EDIT: That would be M.A.D. Yo! LMFAO i'm funny
