Boost_victim's Build thread
Build threads do not belong in the Tech Section.
Pay attention where you post. Thread moved.
jmcboost
Missouri
Updates......(for boost victim) everything is off of the head except for the timing belt. The crank pulley bolt is nice and tight and I've gone through :
1 stanley 19MM socket,
3 craftsman ratchets (3/8 drives)
1 craftsman 1/2" to 3/8" converter
1 stanley 1/2" to 3/8" converter
So the next step is to get a 19MM 1/2" drive socket and try that. Anyway, its getting there. Once I get the crank pulley bolt off, then its all down hill from there. :biglaugh:
jmcboost
Missouri
Yes!! Got it with some PB blaster and a 19mm 1/2 driv socket. I should have the head off tomorrow. Kenny, you should post the pics up that I sent you of the engine bay.
boost_victim
here
myspace.com
head is off new pictures in orig. link.
i have a dilemma, to go mhg or not to?
non metal head gasket:
Felpro head gasket arp studs.
metal head gasket:
cometic and arp studs.
need some help which would be a better route?
supraguy@aol
Well-Known Member
Dec 30, 2005
4,283
78
Atlanta
I went Felpro w/ ARP's for a year and a half, around 12 psi on stock CT, no problems.
I guess it depends on what kind of power you're going to demand from the motor.
boost_victim
here
myspace.com
thats about what i want is some thing around 10-12 psi. nothing crazy, the head i getting checked tommorow for warpage and cracks. i am probly going to go with the felpro. i figure that after its all said and done its going to cost about $350 in parts + some odds and ends here and there. a.k.a oil, coolant, etc.
