Boost leaks / Vacuum leaks
isnms
United States of America
Oklahoma
i80.photobucket.com
And my smoke machine to find them :D
Back2Basics
Regular
Dec 30, 2005
317
Milwaukee, WI
Well thats fancy/probably very effective way. I dont know if I could put something together like that, but do you think my Scunci steam cleaner would work like this?
jetjock
creepy-ass cracka
9,439
Glad I could help. My machine is much fancier but considering commercial ones cost from $600-$2000 I'd say you did pretty darn good for a first try. Try adding a little baby oil to the glycerin or spring for some commercial fluid when you get the design tweaked in. Once you learn how to use it you'll wonder how you ever lived without one. Higher pressure is better for boost leaks but for all the other stuff a low pressure smoker can't be beat. You'd have to pry mine from my cold dead fingers. Do some searching for use tips. Here's a couple of the many helpful articles out there:
http://tinyurl.com/344an4
http://tinyurl.com/ysws7g
isnms
Oklahoma
i80.photobucket.com
I'll see if I can find my laundry list of parts.
Just off hand:
It's a tire pump with a auto resetting circuit breaker. A pipe reducer with large and small pvc caps. A 4psi relief valve. Hairdryer wire as my heating element. Tuna can as fluid reservoir.
