So, I've been trying to track down a nasty whistling noise when I boost over 10psi. It was coming from inside the car and I couldn't pinpoint it. I finally found a definite leak coming from the break booster. I can feel the air coming out of the area where the brake pedal meets the firewall.
So my question is, is there a seal that would cause this to happen, or do I need to replace the whole brake booster? I noticed the TSRM shows a seal/gasket that goes in between the firewall and the booster.
Also, as far as I can tell the leak only happens the most when the brake pedal is fully depressed. If I pump the brake pedal, the leak seems to goes away.
Any help would be great!
