Boost gauge
whudafux
Formerly dcrusupra
Jan 5, 2006
1,034
Cullowhee, NC
I hooked up my boost gauge but it's not reading any boost. I hooked it up to the vac line coming from the back of the manifold going to the cruise control unit. It looked like it was hooked up there in most of the threads I looked at. Any help?
PS - And yes it is hooked up to the back of the gauge, lol.
whudafux
Formerly dcrusupra
Jan 5, 2006
1,034
Cullowhee, NC
It's a Stewart Warner boost gauge. It's mechanical so the only thing to hook up is the light, and it's only a boost not boost/vacuum and it stays at 0. I guess I should've mentioned that the car is not moving when I'm looking at it. I'm only revving it. Not sure if it matters tho. I just thought I would add that.
OneJoeZee
Retired Post Whore
aboard the Argama
It's a mechanical gauge, so there's only so many things that would cause the gauge to not read. Hose not attached at one or both ends > proper vac source > kinked/pinched hose > faulty gauge.
whudafux
Formerly dcrusupra
Jan 5, 2006
1,034
Cullowhee, NC
Well, if it's a faulty gauge someone has some explaining to do. Lol. But I don't think it is. I blew into it and the needle went up. Is that a good place to draw vacuum for the gauge from? And I'll check on the hose to see if it's pinched or disconnected.
jsnowman76
In need of another supra
Oct 17, 2006
289
Elk grove, CA
if you have a brand new t fitting you should be fine. double check on the pinched hose. the previous owner of mine hooked it up by cutting a vacuum line and then used scotch tape to secure it. and then when he sold me the car he was wondering why it woulnt read anything.:3d_frown:
