Boost gauge
JASONA70
nomnomnom
Oct 27, 2006
743
socal
i bought an electric boost gauge from prosport, but some how it wont work. i connected the sender to the ground and 12+ and connected it to the boost gauge itself, it wont read the boost. it reads -20 vac (this gauge is in PSI) i connected the vacume to the intake/bov. im guessing its the wrong spot to put it. the instructions says connect it to the pressure regulator and serge tank. which i have no clue what these things are.
fuel pressure, where do i connect the sender. (not ever good with electical stuff) =\
here is a sneak peek ^^
http://i121.photobucket.com/albums/o235/SuperSupraKid/100_0472.jpg
JASONA70
nomnomnom
Oct 27, 2006
743
socal
johnathan1 said:
surge tank=intake manifold
I connected my boost gauge to the line running accross the firewall that goes to the heater valve, just before the check valve.
where is the pressure regulator???? -_- that should be the bov. oh yea my supra cant make it to autobacs this week. =\ but ill be there with eric with his supra ^^
Van Diesel
Powered by vino
Dec 12, 2006
396
El Paso, Texas
don't make this complicated. Connect the boost gauge to any nipple on the intake manifold. If no nipples available, then cut and "T" one.
JASONA70
nomnomnom
Oct 27, 2006
743
socal
yea i did that, i think something is either wrong withmy sender or the gauge. :nono: i mean its not taht hard, anyways bump for the fuel pressure help.
OneJSupra
I'm a sleeper ...
Feb 9, 2007
900
Supraland
here's your answer simple and it works.
JASONA70
nomnomnom
Oct 27, 2006
743
socal
yea i figured the boost gauge is defective, i have a fuel pressure gauge. im just wondering how do you install it? im guessing the fuel rail but need more info. thanks the instructions didnt come with the sender instructions
OneJoeZee
Retired Post Whore
aboard the Argama
It would probably be better to leave the vacuum source of the fuel pressure regulator alone...
This is a 1J, I know you have a spare vacuum source on the intake manifold somewhere. :)
btw, your car looks too much like mine. Get dat shit outta here.:D
JASONA70
nomnomnom
Oct 27, 2006
743
socal
yea i finished connecting the boost, now i need to connect the fuel pressure gauge, where do i connect fuel pressure sender?????
my car does look exactly like yours, it even has the rear sunshade and the silver wheels. but brown interior =\
Van Diesel
Powered by vino
Dec 12, 2006
396
El Paso, Texas
to install a fuel pressure gauge, you'll need to put the gauge somewhere along the fuel line from the "out" of the fuel pump all the way up to the fuel pressure regulator. I like to measure fuel pressure after all the fuel goes thru the injectors and before (or in) the FPR....which would mean an aftermarket FPR.
