boost gauge
sweetlikechutny
235
Ontario
it measures how much pressure is in the pipes after the turbo and before the engine. Then it shows you the amount of pressure in psi or lbs/in on a dial.
ms07s
TORGUE!
Sep 29, 2007
1,083
Memphis,Tn
The boost sensor is on the driver side engine bay with a vac line on it. On the same bracket as the ignitor IIRC. Have a problem or just curious?
87M-GTE
Slow
Sep 12, 2007
1,705
Milwaukee WI
It is not on the ignitor, it is on the injector resistor.
Mine has a sticker that says "turbo pressure" on it with a PN, etc.
Sam
