Boost Controller
87soup
F*CK SMOG CHECKS!!!
Jan 23, 2006
864
Sacramento
Ok so i hooked up the through piece instead of the boost controller and i got stock boost!!!:icon_bigg
Then i hooked up a turbosmart boost controller (bran new) and the same FUCKIN thing happened... BOOST CUT!!!:3d_frown:
What do i need to do???
PLEASE HELP MY SOUP:1zhelp:!!!!
87soup
F*CK SMOG CHECKS!!!
Jan 23, 2006
864
Sacramento
OneJoeZee;925017 said:
Sounds like your boost controller sucks are you're not hooking up the lines correctly to it.
No... Both boost controllers works perfectly on my buddy's 300ZX, then when i hook it up the the supra i run into this problem!!!
I know the lines are correct because when i join them together with out the boost controller it works like stock!!!
Could i be one of my Waste Gates??? :aigo:
WTF???
87soup
F*CK SMOG CHECKS!!!
Jan 23, 2006
864
Sacramento
OneJoeZee;925059 said:
I mean the lines hooking up to the controller. Are you sure it's not backwards?
I flipped it both ways tho... Have you ever ran into anything like this before???
87soup
F*CK SMOG CHECKS!!!
Jan 23, 2006
864
Sacramento
Does that help???
87soup
F*CK SMOG CHECKS!!!
Jan 23, 2006
864
Sacramento
Does the 1jzgte need a specific boost controller or something???
The same boost controller work just fine on my friends z32.... :cry:
87soup
F*CK SMOG CHECKS!!!
Jan 23, 2006
864
Sacramento
I tried it with bolt lose and tight... I even tried a bran new TURBOSMART boost controller none work for me but both work for my buddy's Z32!!!
black89t
boost'en down 101
Oct 27, 2007
951
humboldt, ca
try to blow through it. from the pic is looks like you have the bolt tightened down all the way. i had to blow through mine to find out my mbc was backwards. the + gave it less boost and - gave it more boost. it's just a valve that restricts the pressure. the more pressure it restricts the more boost you get. if you can't blow throw it that will be like running no waste gate. make sure it is fully released by blowing through it and start tuning it from stock boost. that would be my guess to what is wrong.
T701jz
3M ENGINEER - R.&.D
Jul 23, 2005
657
Santa Clarita Ca.
Twin Turbo
2 waste gates
2 vacuum ports
MBC
Supply
Exhaust
(T) both of the waste gates.
Cap off one of the vacuum port.
Connect one of the vacuum ports to the MBC supply.
Connect (T) both of the waste gates to the exhaust.
Use equal length lines from MBC to the waste gates.
Adjust Mbc to desire boost.
87soup
F*CK SMOG CHECKS!!!
Jan 23, 2006
864
Sacramento
T701jz;965843 said:
Twin Turbo
2 waste gates
2 vacuum ports
MBC
Supply
Exhaust
I will try this and let you know... Sounds like the only thing i havent tryed yet!!!!
