I decided that my other thread in the general section wasn't helping me much because it has nothing to do with my current problem and I wasn't getting much help out of it. So I just went through swaping my new CT onto my 7M and I checked out everything from vaccum lines to intercooler pipes. Everything was actually going really well untill it came time to start it up for an oil change... well I accidentaly tried starting it twice with the AFM unpluged and it dyed just as fast as it ignited. So I plug her back in an start her up just fine. Once everything was back together I took it for a ride through the neighborhood and noticed a strange bogging at about 1200 rpm and the check engine light was on... I check the codes and came up with 31 and 24 wich im told only happens when your AFM has a bad connection. So i cleaned the contacts and cleared the codes then started her up. And now it idles fine for about 20 seconds and bogs down till the engine stalls. I'm told this is caused by a vaccum line or IC pipe but i cant find anything wrong, no pin holes... nothing and I have no error codes now. All my lines are the same as before I started this swap and before it drove great and boosted to 5psi wich it currently is still only boosting to. HELP lol
