Blueish fluid?
Topher E
Trance Head
Aug 4, 2005
388
Vacaville
Blinker fluid.
Do you hahve a 5 speed or Automatic. Either way, its transmission fluid/gear lube. Just top it off.
Supracentral
10
For a stock car, use stock lube. 3 liters of SAE 80W-90 GL4 or 5 Gear Oil
Use redline shockproof if you are putting down big power.
royal purple here....
helped smooth 1st and 2nd on my car (it's just a way for it to last a bit longer before I rebuild it...)
Supracentral
10
I think he's saying it's odd to see someone with substantial mods (cammed 1jz with a t67) who doesn't know the basic fluids the car needs.
jdub
Feb 10, 2006
10,730
Valley of the Sun
slowsupratt said:
What exactly do you mean?
For the care an feeding of a 7M, 1J, or 2J motor...you really need to pay attention. There's a ton of info on fluids...highly suggest you read it.
For your car, Red Line MTL in the tranny will be more than sufficient for the power a 1J is capable of ;)
