BLOWN TURBO
RTA Supra
MA70 Enthusiast
13
Tampa, FL
gnarkill87 said:
either rebuilt (ct26) or ill just get like a new t4 or something along those lines.
if you've got the cash, get the T4 turbo. You've got just about everything you need motor wise to go that route.
Turbo, manifold, wastegate, oil lines, custom dp, and exhaust and you're good to go.
Nalleywhacker
Formerly gnarkill87
Oct 2, 2006
643
chattanooga,TN
just bought a t4. rta ill be doing some custom stuff to fit this thing but its going on there ill send you a pic when its all done!
Nalleywhacker
Formerly gnarkill87
Oct 2, 2006
643
chattanooga,TN
Idealsupra said:
um wow...you successfully downgraded your car.... good job
not really my ct26 is blown and only running 4psi and smoking like a bitch i know its not going to last more than a year but its something for now untill i can afford to do a good upgrade.
Idealsupra
Orlando
www.tampabaysupras.com
you DO understand you will need at the least an adaptor to bolt that turbo to the block, oil lines (it says it comes with some but i doubt they are anything close) and a vband custom downpipe... not to mention some sort of intake assuming the accordian hose doesnt fit on that. so youre going to spend the 300 on that, and at LEAST another 300 on the other things... you might as well have picked up a rebilt upgraded ct26 like 57 or 60-1 trim... that would bolt right on....
MKIIINA
Destroyer of Turbos
Plano, TX
that turbo sucks man. itys way smaller than a stocker, you need an adaptor, an dp at the to get it to work. 4 psi on a blown ct26 is way better than what will be 8 psi on that turbo. you shoulda really cheaped out and just got your stocker rebuilt until you got some money and gotten a real turbo. sorry man but thats how it is
Nalleywhacker
Formerly gnarkill87
Oct 2, 2006
643
chattanooga,TN
alright thanks man we will see. ill let you know how it does i know its cheap but i have to pass emissions were i live so having a blown turbo that smokes is not an option i had to do something and i literally have no money!
