blown EFI fuse.....HELP!! please
basballr04
14
Evansville IN
my car was having trouble idling for about a week and then i was going down the interstate near my house and my car shut off.....stupid me, i thought it was just the factory fuel pump that went out so i changed it, who would've thought, I had a blown EFI fuse......any help as to how to get my car back and running??? I know theres probably a short somewhere but where to start??
Squid699
Manic Mechanic
Chesapeake, VA
I just had this happen to my car. Lemme guess, the car has trouble idling especially after a hot start and a short rest after driving around?
Mine was caused by faulty wiring in the harness. 18 year old car - the wiring is starting to degrade. You need to break out your multimeter and check your circuits from the sensor to the ECU and see where the problem lies. A TSRM, online or otherwise, will be very beneficial
dbsupra90
toonar
indiucky
number 1 cause of a blown efi fuse is a melted 02 sensor wire.
check the 02 wiring to see if it got melted by the exhaust manifold.
basballr04
14
Evansville IN
squid your exactly right, it had been going on for about a week or so, then the fuse blew
i enjoy working on the car but i sure would love to keep some money for myself
Oct 11, 2005
3,821
25
Thousand Oaks, CA
Another common one is the harness rubbing through the insulation where is goes across the intake manifold from the firewall. It should be supported off the intake runners by several wire clips, but they disintegrate over time.
dbsupra90
toonar
indiucky
basballr04 said:
would the efi fuse blow if the main relay went bad??? just wondering before i go out into the heat n under the hood
anything on the +B line shorted to ground, including the main relay and circuit opening relay. also check the egr wiring. it often melts as well.
Squid699
Manic Mechanic
Chesapeake, VA
If you've removed your EGR, BVSV and the VSV or anything else, make sure you don't have any wires flapping around that may be chaffed and can short out when you go around a turn or something by hitting the manifold or block.
basballr04
14
Evansville IN
well i did diagnostics on my car and i got a code 22.....weird i know, water temp sensor.....so i unplugged it, blew in it a lil bit, plugged it back in and now my car is up and running......now all i have to do is figure out my overheating problem and i should be done for awhile....atleats until i get my cold air intake and do a lil exhaust work in the next couple months, thanks for all the help guys.... i'm sure ill be back sometime soon with some other problem
