blow off valve isn't blowing off
alexscof
70
Pullman, Washington (WSU)
I believe I'm just getting compression surge. I hear that famous flutter regardless of boost. I have an all stock setup except I have an ssqv, which came on the car. I was going to recirculate it but all of a sudden its not functioning correctly. From what I've read it is probably a bad vacuum source. I blew out all the vacuum lines going to the bov but it didn't help. Thoughts?
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Try to blow through the line when the engine is cold - just disconnect it from the BOV, and blow in the end. If you can't, the line is plugged, which is rather common. Often it'll still work when hot, because the line gets plugged with gummed up old oil from the PCV system over the years, and it gets soft enough to let the vacuum signal through when hot.
If it's plugged, you'll need to disconnect it at both ends and blow it out with some solvent. I'm a big fan of brake cleaner, myself.
IwantMKIII
WVU MAEngineering
Jun 12, 2007
2,477
Perkasie, PA
you should search my name and all the ssqv thread's ive started. it will inform you all you need to know. i'm sorry ahead of time.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,242
Atlanta
My BOV stopped working not too long ago.
Found out it was the vac line disconnected at the PS pump.
That one becomes the hard line that crosses your lower timing cover, and feeds the entire vac rail.
