bleeding clutch slave cyl....
rakkasan
Currahee!!
Fort Campbell, KY
I'm having trouble getting the clutch bled. I'm using a vacuum pump bleeder on the slave cyl, but I'm not having any luck. The clutch pedal isn't returning all the way after depressing it, so I'm stuck. Any help would be great, this is my first pull type clutch, so I'm a little lost with it.
When I first installed my five speed, I had the same problem. I kept bleeding it but the pedal still wouldn't come off of the floor. There is an adjustment on the pedal itself that I had to move in order for the pedal to start coming up off the floor. I don't know if this helps you or not, but it solved my problem, well one of my many problems, but that's another discussion for another day.........good luck...............lol
