what is the biggest cylinder bore possible on the 7m i've seen once a guy claimed .80 over the biggest i've seen is .40 so what is the limit?
mrnickleye said:30 over is safe for sure. You could also have the block sleaved back to stock.
If you go too much, you run the risk of too hot, and then the cylinder will distort. Depends what you plan on doing, and how much strain you are gonna place on it.
To add to that.If you go too much, you run the risk of too hot, and then the cylinder will distort.
Isphius said:this is an old thread, but it needs so revival for my cause. What is the biggest safe bore in mm? some say 85..other 84..86...anyone have a definate idea?
miggles said:Ive gone a ants dick over
IJ. said:The other bad side effect of large bores is they tend to run hotter which in a 7M is a disaster waiting to happen.
What's the air speed velocity of an unladen swallow? :rofl:jdub said:Australian standard? How many ant's dicks make up a mm?
And are those African, Asian, or N American ants?
