Big HP boys what clutch are you using? (2JZ/R154)
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
LOL - actually, that switch is so that you can run decent quarter mile times... and while there are Supras that hold their own quite well on the drag strip, it's not what they excel at. There are plenty of folks pushing 1000+ through manuals, and several clutches that hold fine.
bigshooter44
19
new york
im running the os giken twin plate grand touring rated at 650 torque i believe.. granted im only at 450ish atm but that wont be for long :icon_wink pedal pressure is pretty stiff and takes some getting used to.. and some chattering in first gear stop and go.
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
I've driven the OS Giken unit, and I wasn't impressed. It may hold, but it's loud, it shudders in 1st / reverse from a stop, and it has a pedal that's as hard as many single discs. There was a WORLD of difference between OS Giken and Tilton.
I really wish I had someone local I could test drive the RPS unit on.
Dan_Gyoba
Turbo Swapper
Aug 9, 2007
1,836
Alberta
www.gyoba.com
I thought that the point of a multi-disk clutch was to eliminate these things that you get with a puck clutch.
