big cams
mkiiichip
1,434
WI
Are you thinking of having custom cams ground, all of the cams available require no grinding. Where are you going with this?
quake
toyota tech
Apr 13, 2005
619
r.i.
thanks guys still checking the specs got cams in already and looking to shift the power band a bit
suprarich
Guest
Nov 9, 2005
2,187
ohio
BlackDevilSupra;1673575 said:
Just about 9mm lift
You just happen to about right. In fact, I have found that it will vary from head casting to head casting. I have fit 9.2mm before with out having to make clearance, but then on some of the castings, I had to grind the head for 9mm cams.
