Big 1jz build in Chicago
Jostar
AEM powered 1JZGTE!!!
May 21, 2007
746
Chicago
Hey guys, Just wanted to show a little preview of what I have been doing in the past few months..
This is my Baby..
There is more but that is more than enough for a preview lol.....
rwd
60
quebec
gt4294r???i'm courious to see how it will spool on 2.5L...but you'll have ton of power.
which cams are you using? a/r on turbine side?
johnd
278
Ont. CA.
also curious
Jostar
May 21, 2007
746
Chicago
HI guys, Thanks for the kind words, The turbo is a PTE GT4276, I should be able to spool it around 5k but don't quote me till I get it tuned, The head is built, HKS 272s, Ferrea complete valvetrain (can rev to 10k if I wanted to lol) A lil porting, I do have the supporting mods for the turbo, For now I am gonna tune it for pump gas around 18-20 psi, Then C16 to see what it does, Next year the plan is to move to E-85 & PRO-EFI, SO keep your eyes open for my AEM for sale lol....
Jostar
May 21, 2007
746
Chicago
Supporting mods are..
HKS 272s
HKS cam gears
HKS timing belt
HKS EVC 5
Fully built 1JZ head with Ferrea valve train
PTE 1000cc injectors
Driftmotion top feed rail
Driftmotion AFPR kit
TT pump (12volt mod)
Bosch 044 (inline) with -8 from toyota filter to rail (Bunch of AN fittings)
AEM ems
FJO Old skool wideband (big box green display)
Chinaman Exhaust manifold modded by SP (better welding & flange for a 46mm)
PTE GT4276
PTE 46mm Wastegate
SP 4 inch downpipe
SP 4 inch Mid pipe
ETS 4 inch Cat-back
Getrag (freshly rebuilt)
RPS strapless Carbon/Carbon twin disk
SP modded tripod t fit the MKIII
SP chromoly 1 piece driveshaft
Arizona performance front 6 piston caliper kit
Tein HA coilovers
BFG drag radials
Hoping to make good power….
Jostar
May 21, 2007
746
Chicago
The head is built for that rpm but the short block wont last too long at 10k. But i believe i should have more than enough power under 8.5k
Jostar
May 21, 2007
746
Chicago
I worked my ass off, save save, people have told me I should have bought a MKIV but i love my MKIII. With the money I have dumped in the past I could have bought a nice Mkiv.
OneJSupra
I'm a sleeper ...
Feb 9, 2007
900
Supraland
Nice build. Or you could have just gone full 2J. With that big turbo and v160 would have been perfect match IMO. g/l with it.
te72
Classifieds Moderator
6,618
9
WHYoming
Heh, my current goal is to save 8k by the end of May for a parts shopping spree to actually finish this car up... head is built to be a mid range monster, I'm rather curious to see how your car runs with this setup. Hopefully you'll be done by the time I sink some cash into a turbo. :)
Jostar
May 21, 2007
746
Chicago
^^^That will hold alot of power, talking to SP they believe that the 1Jz rods can hold more power than the 2jz rods, pistons are made if the same material if i remember correctly, you will be fine, after i reach my goal of 700-800hp at SP mustang dyno i will start saving for a better long block, I wanna try a new head that a friend is gonna work on, My friend Chris from head dynamics can make a head flow... he looked at my head once & was amazed on the stock ports, he said he has done a few 2jz heads& believes the 1jz can definitely flow alot more than a 2jz with the same headwork. We will see in the future.
