bic mounts wtf
Ds650rida
215
Jersey
has anybody used the bic mounts on a soarer 1jz? i was pretty sure the mounts were the same on either, the website does not specify a supra 1jz. The mounts are totally off and now i'm not sure which goes on what side, because apparently the soarer motor has the same bolt patter on both sides. If anybody could give input on this it would be great, i'm about to just customize the mounts myself.
Bigzavs
86.5 1JZ Single Turbo
Apr 21, 2005
2,267
Arlington, TX
drivers side
you have to change which bolt holes you use, you have to unbolt the fuel pulsation dampner and use those bolt holes for the rear of the mount, then you have to have the bolts go through the dampner, mount, and then into the block, i can take a pic tomorrow when i get my car back for you if you want
pass side shouldnt have any problems
