well, I've got a 5 psi-15psi adjustable wastegate actuator on my turbo, I've got the spring set low, around 5 psi.  Well, when I get to 5 psi under WOT, it settles there for a second, and I can hear the dump on the DDP open.  The dump stays open, and then the boost takes off....  5-10-13-15....+  I've seen 20 psi one time.
The wastegate flap is larger than the ct, I'm wondering if it is partially blocking the dp dump tube and causing my boost creep. Any other ideas?
